Fibre Channel (SAN) Technical Documents
Chassis is not ready for management now. Please try after some time.
by on ‎10-16-2009 10:02 PM - edited on ‎10-30-2013 01:14 PM by Anonymous (12,348 Views)
Notice: The information in this Contribution is provided “AS IS,” without warranty of any kind.
The author TechHelp24 reserves the right to make changes to this document at any time, without notice, and assumes no responsibility for its use.
The author TechHelp24 shall have no liability or responsibility to any person or entity with
respect to any loss, cost, liability, or damages arising from the information contained in this contribution.
Some user reported at several times about the problem
"Chassis is not ready for management now. Please try after some time."
Here is the Workaround.
Log as root and execute
Brocade4100:root> /fabos/libexec/webdconfigure
HTTP attributes (yes, y, no, n): [no] y set to y or yes
HTTP Restart (yes, y, no, n): [no] y set to y or yes
HTTP enabled (yes, y, no, n): [yes] must be set to yes also enable.
ErrorLog Enabled (yes, y, no, n): [no]
AccessLog Enabled (yes, y, no, n): [no]
SSLLog Enabled (yes, y, no, n): [no]
HTTP Port: (1..60000) [80]
Secure HTTP Port: (1..60000) [443]
HTTP IsAlive Check Enabled (yes, y, no, n): [yes] must be set to yes
HTTP Max HeapSize: (256..1024) [256]
webtools attributes (yes, y, no, n): [no]
cal attributes (yes, y, no, n): [no]
Exit from /webdconfigure and try as root "hareboot"
Comments
by Anonymous
on ‎07-14-2014 06:38 AM
Hi,
I have similar issue. and I am planning to make above stated changes. However I am bit new in this Fabric world so just willing to have few checks.
Q 1: I can straight away perform hareboot on my 5840 series (6.4.0c) - I read some thread stating, execute it on active CP. if that is the case, how can we execute hareboot on active cp.
Q2: As I can see the command is hareboot, is there any remote possiblity that it may interrupt FC traffic even for a milisecond on my 5480 embedded switch gear having FOS 6.4.0c
Your answer is highly appreciable.
Thanks
VM
by
on ‎09-18-2014 12:00 AM
Hi,
In response to your queries:
Q1: Yes, you can. 5840 has only one CP (so it is always active). In order to execute it, just run commnad 'hareboot'
Q2: Theoretically, it does not affect FC traffic, but in this world of ours nothing is 100% secure and the remote possibility of a failure always exists.
On the other hand, FOS 6.4.0c is a little bit old and I recommend you to upgrade to the latest release supported by your switch.
Rgds,
Felipon
Contributors
