Anonymous
Port issue
Hi ,
I need an assistance on this error message. Can somebody tell me what was the cause for this error message on this particular port.
External Moderator
Re: Port issue
elmoandsam,
sound not good. Hardware Error.
For exact details, log into the switch as admin trugh CLI, with the command "errshow" ........ get a output of all error are caused by the switch.
TechHelp24
Message was edited by: TechHelp24, Message was trunkated
TechHelp24
Anonymous
Re: Port issue
Hi
Thank you for the respond, yes I have look into the error report using web base and I realize something wrong with SFP cable so I replace the cable, before I replace the cable, I disabled the problematic port. Once the port been disable I plug in new SFP to SFP cable and enable the port back to normal position. Surprisingly everything went smooth. Now the switch port 20 no issue. I think the cause of this error on the port is due to the SFP cable, correct if I'm wrong. Thank god now everything works fine. Thank you.
