Turn on suggestions
Showing results for
10-15-2012 11:36 AM
We purchased two DCX-4S director switches with two additional 48 port blades. The unit was shipped with the blades at the bottom of the switch.
Is there a problem with us moving the blades to the top two slots of the switch?
Trying to figure out cable length and rack space.
Thanks.S
10-16-2012 09:59 PM
Excepted Core and CP Blade, you can fit Port Blade to any free Slot as you prefered.
there is "NO restrictions"
