Occasional Contributor
Brocade 6520 - change air flow direction
Hi,
We have a pair of Brocade 6520s with front to back air flow. We're looking at installing these in a cold aisle arrangement, with the ports being on the outside / warm side of the cold aisle.
Is it possible to simply swap the PSUs and fans so the air goes the other way e.g exhausts on the port side? Does anyone have part numbers?
Thanks
Senior Member
Re: Brocade 6520 - change air flow direction
Hello,
I would like to refresh the topic.
Does anyone changed, in switch 6510 or 6520, fans / power supplies to change of air flow?
Best regards,
Waldemar Rosiński
New Member
i do have the same issue. can anyone answer below query.
External Moderator
@vbhimireddy
see follow topic.
https://community.brocade.com/t5/Fibre-Channel-SAN/Airflow-6510-must-I-replace-the-switch/td-p/89327
for 6520 you need to replace both PS and FAN, airflow cannot be change trough a command
TechHelp24
