Turn on suggestions
Showing results for
09-15-2010 01:21 PM
cbr backup connects to switch and shows output for backup but is not saving to a file. only the log file is populated.
09-15-2010 10:08 PM
Switch Type/Model ?
EOS Release ?
CBR Release ?
09-16-2010 08:57 AM
i have several mcdata DS32-M2s, running FW 09.08.01. CBR version 9.1. the gui works but would like to automate using CLI.
CLI output shows --- but backup xml is empty
onnected to Switch
Requesting for Backup
Retrieving Firmware Version...
Firmware version: 09.08.01
Firmware build id: 2
Retrieving Switch Information
!!! unrecognized Switch Information: Frame Resize State,Enabled,
Retrieving OSMS Information
Retrieving Port Information
Retrieving SNMP Information
Retrieving Zone Information
Retrieving Port Status
Retrieving Installed Features
Retrieving PortBinding Information
Retrieving SwitchBinding Information
Retrieving FabricBinding Information
Retrieving Syslog Information
Retrieving FiconMgmtServer Information
Error 165: CUP Zoning feature key must be installed
Retrieving NPIV Information
*** Disconnected
09-16-2010 09:20 AM
Hi,
see please this Thread here.
http://community.brocade.com/message/12755#12755
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
09-16-2010 11:31 AM
9.1 is the latest Release, no other are available.
Your can use DCFM, but I'm not sure if the For Free Prof. Edition can create a Backup and/or if this Feature is available in the Free Release.
