Anonymous
port can not login (Switch not ready for F or L ports)
Hello Experts,
I have a problem in my fabric that i can't connect the HBA and get it online . If the same connected to another SAN fabric it comes online.
This problem happens any serer 4G , 8G connects to any switches in that fabric newly or relogin doesn't happen at all .  Where to look what to do
QDC_SAN_2499_02:FID128:admin> portstatsshow 1/2
stat_wtx                283336      4-byte words transmitted
stat_wrx                114         4-byte words received
stat_ftx                23600       Frames transmitted
stat_frx                3           Frames received
stat_c2_frx             0           Class 2 frames received
stat_c3_frx             3           Class 3 frames received
stat_lc_rx              0           Link control frames received
stat_mc_rx              0           Multicast frames received
stat_mc_to              0           Multicast timeouts
stat_mc_tx              0           Multicast frames transmitted
tim_rdy_pri             0           Time R_RDY high priority
tim_txcrd_z             0           Time TX Credit Zero (2.5Us ticks)
tim_txcrd_z_vc  0- 3:  0           0           0           0
tim_txcrd_z_vc  4- 7:  0           0           0           0
tim_txcrd_z_vc  8-11:  0           0           0           0
tim_txcrd_z_vc 12-15:  0           0           0           0
er_enc_in               0           Encoding errors inside of frames
er_crc                  0           Frames with CRC errors
er_trunc                0           Frames shorter than minimum
er_toolong              0           Frames longer than maximum
er_bad_eof              0           Frames with bad end-of-frame
er_enc_out              8           Encoding error outside of frames
er_bad_os               43261798    Invalid ordered set
er_rx_c3_timeout        0           Class 3 receive frames discarded due to timeout
er_tx_c3_timeout        0           Class 3 transmit frames discarded due to timeout
er_c3_dest_unreach      0           Class 3 frames discarded due to destination unreachable
er_other_discard        0           Other discards
er_type1_miss           0           frames with FTB type 1 miss
er_type2_miss           0           frames with FTB type 2 miss
er_type6_miss           0           frames with FTB type 6 miss
er_zone_miss            0           frames with hard zoning miss
er_lun_zone_miss        0           frames with LUN zoning miss
er_crc_good_eof         0           Crc error with good eof
er_inv_arb              0           Invalid ARB
open                    0           loop_open
transfer                0           loop_transfer
opened                  0           FL_Port opened
starve_stop             0           tenancies stopped due to starvation
fl_tenancy              0           number of times FL has the tenancy
nl_tenancy              0           number of times NL has the tenancy
zero_tenancy            0           zero tenancy
fabric -s ==> partial
Switch 0; Tue Apr 23 15:42:16 2013 GMT (GMT+0:00)
15:42:16.968563 SCN LR_PORT (0);g=0x156                     A2,P0  A2,P0  2     NA
15:46:38.962069 SCN LR_PORT (0);g=0x156                     A2,P0  A2,P0  2     NA
15:47:01.931464 SCN LR_PORT (0);g=0x156                     A2,P0  A2,P0  2     NA
Valued Contributor
Re: port can not login (Switch not ready for F or L ports)
portcfgeport?
Anonymous
1. Did you connect the cable in a proper way ?
if Yes
2. Did you try connecting the same cable to some other port on the switch?
if yes
pls paste the switchshow output of working switch and non- working switch
