Occasional Visitor
can i use same blades in DCX8510-4B and in DCX8510-8?
Hi All,
short and quick...
can I use same blades in DCX8510-4B and in DCX8510-8?
16GB-48 Port
External Moderator
Re: can i use same blades in DCX8510-4B and in DCX8510-8?
[ Edited ]
@BeLocal
all, 16G Port and Application Blade ( excepted FCOE10-24 is only supported in 8510-8 ) are supported in both chassis 4 and 8 slot.
FC8-xxE = Enhanced and FC8-64 Blade are not longer supported begin with FOS 8.2
all this details are descripted as well in the FOS Release Notes.
TechHelp24
Frequent Contributor
Core blades are also unique to the 8-slot and 4-slot chassis. Just in case ;)
