Anonymous
autoneg / fixed speed
Hi,
Anonymous
Re: autoneg / fixed speed
We had similar recommendations in the past from our support - HDS - and locked everything at 10/Half which did resolve the communications problems that we were experiencing. IMHO this comes into the "if it's not broken, don't fix it" category. If you aren't experiencing any problems then resist the change unless your HP support can provide a valid reason for implementing it.
External Moderator
Disable auto-negotiation is surely not a fix to solve any problem, however the error are most caused by malconfigured HBA / Array Control Processor port Side. I do not know any Brocade Documentation where is described, that Auto-Negotiation must be Disable or Fixed is reccomended. Disable any Option generally is the fast way to resolved in short Time any Problem, but not a Fix.
TechHelp24
Anonymous
Thank you for your replies Bernd
Anonymous
I asked exactly same question to a Brocade trainer and she said Brocade Engineering told her the only side effect of using autoneg was that certain error counters were incrementing more often than were with the fixed rate. I think it was enc_errors if I remember well. The ideea was: Leave it into autoneg and if you see error counters for a certain port incrementing too fast try to set it fixed. if still continues after that something is broken and needs replacement (cable HBA, SFP, blade, etc). If the error counter stop incrementing, all was caused by autonegotiation problem and is better to set it not to negotiate, but is not necessary to replace hardware.
