Turn on suggestions
Showing results for
03-31-2011 06:54 AM
Please find the alert which we got today on 48000 director. Sfp RX power 10, is above high boundary(High=5000, Low=0). Current value is 6553 uWatts.
Do we have to take up any action or ignored.
Thanks,
04-02-2011 07:50 AM
You should check the SFP specs of the affected port. If this is within the operational values change the fabric watch settings.
I hope this helps,
Andreas
