Occasional Contributor
SNMP returns different data from two identical switches
Trying to get a monitoring package to collect data from two 4020 gateways in IBM chassis. One swicth reports back ALL data and performance metrics as designed. The other reports NO internal copper FC ports info, just  the two fibre trunk ports for the uplinks. Using a MIB browser with FCMGMT-MIB I can GET:
Sent GET request to 172.27.7.143 : 161
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.1
10 00 00 05 1e 04 eb f4
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.2
00 00 00 00 00 00 00 00
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.3
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.4
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.5
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.6
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.7
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.8
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.9
20 01 00 1b 32 b8 ec 33
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.10
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.11
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.12
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.13
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.14
20 01 00 1b 32 be 97 66
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.15
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.16
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.17
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.18
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.19
connUnitPortNodeWwn.16.0.0.5.30.4.235.24 4.0.0.0.0.0.0.0.0.20
On the other switch i GET:
Sent GET request to 10.4.5.6 : 161
No data available in this sub-tree
both switches are Brocade 4020  running FOS   v6.2.2d as ACCESS GATEWAYS
Any help appreciated
Valued Contributor
Re: SNMP returns different data from two identical switches
I don't believe in miracles. Did you already compare the configupload output from both switches?
