Anonymous
ISL trunking between Brocade 4900 and DCX-4S Director
Hello Team,
I am new, and please I would like to share your experience in ISL trunking.
In our DataCenter, I have a Brocade DCX-4S. I would like to extend my fabric to a second data center far from 200m. Between the two data centers,  We have fiber repeaters called ODF (LC-SC fibre), responsible for taking the signal from one end to the other of the two data centers. And the type of fibre link is singlemode. I now need to know which SFP to choose for my Switches(4900 and DCX-4S) to enable the communication.
1) My goal is to create ISL trunking (8 links) between my Brocade 4900 and my DCX-4S Director. Is it possible ? since the Brocade 4900 is 4Gbps and DCX-4s is 8Gbps?
2) If possible, my concern is to order some SFP, monomode compatible or Brocade 4 Gbit/sec LWL 4 km SFPs, please advice !!
3) Finally, please is it possible to have a guide for ISL trunking ?
Waiting your feedback,
Thank you in advance
Valued Contributor
Re: ISL trunking between Brocade 4900 and DCX-4S Director
Hi,
In response to your queries:
Yes, it is possible. Both will work at 4Gbps
In the following link, you can find the Brocade Transceiver support Matrix (although 4900 does not appear in the matrix, it uses the same 4G SFPs)
http://www.brocade.com/downloads/documents/matrices/SFP_Matrix.pdf
In the Fabric OS Administrator guide, available in the download section of my.brocade.com, there is a chapter that explains how to configure ISL trunking.
Rgds
Anonymous
Thank you very much for your answers.
Anonymous
Hi,
Can I use Multi Mode Fiber (MMF) cable like OM3 (LC connectors), to get my brocade Switches/Directors connected to the ODF, knowing that the ODFs link is single-mode optical fiber.
Anonymous
Stef
This is generally not recommended. You will have significant light loss between the single mode (9 micron) to MM (50 micron). This will effect your signal quality and ability for the network to perform as per design over this distance.
Valued Contributor
Hi,
I completely agree with , in fact, i thought that doing that could not even be an option...
Rgds
