New Contributor
How to configure SSH on Brocade 6510 and 7840 - novice administrator
Hello,
I have a number of 7840s and 6510s that we traditionally use telnet to access.  REcently weve been told to use SSH so we can eventually block telnet port 23.
I hve found a number of documents but none seem to give me a simple guide to implment SSH.
All devices are at V7.4.1 or V7.4.1b.
I am not familair with the SSH inner workings, setting up SSH is new to me.
Is there a concise cook book to enable 'admin' to log in via SSH?
Former Brocadian
Re: How to configure SSH on Brocade 6510 and 7840 - novice administrator
Moved from Ethernet to SAN
If my response has solved your query please click the "Accept as Solution" button.
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers.
All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
Broadcom Moderator
Hi Phil,
all recent FOS switch supports ssh out of the box - incoming. You can simply type
ssh admin@ip-address-of-your-switch
to ssh into the FOS switch. If you want to put in place ssh public keys on the switch, the following doc is a starting point
http://www.brocade.com/content/html/en/administration-guide/fos-740-admin/GUID-C979B846-B591-4618-8A25-2C1DF2270DF5.html
