New Contributor
How to Clear SNMP v3 Trap Recipient using CLI
Hi Guys,
Good morning.
I received an error "snmp destination table is full on the switch"
upon checking there are already 6 entries. I would like to know how do we remove specific trap recipients on the list using CLI?
Thanks
Best Regards,
Emman
Broadcom Moderator
Re: How to Clear SNMP v3 Trap Recipient using CLI
Hello,
You need to reset to the default setting and then to add used IP addresses.
snmpconfig --default snmpv3
New Contributor
@Thierry.Zimmermann
Thanks for the reply appreciated it.
I created a procedure on "How To's" using GUI, is it thru that it is only possible to remove SNMP recipient only using the CLI?
(haven't tested it since we don't have extra device)
Thanks for the time.
Broadcom Moderator
[ Edited ]
Hello,
I have tried through GUI interface and I was not able to remove it but it is possible to come back to 0.0.0.0 as IP adrs.
New Contributor
You mean, I can set the IP to 0.0.0.0 then Apply, then re-enter the IP Address then Apply again?
Thanks really for the time appreciated it.
Broadcom Moderator
Yes for remove, set 0.0.0.0
