Anonymous
ED48000B with CP faulty (21) before replacement and CP faulty(3) after replacement
Guys,
We Have a customer with a ED48000B that presented amber LED faulty for CP#5 and during slotshow , we got the following :
Slot   Blade Type     ID    Status
  1     SW BLADE     36 ENABLED
  2     SW BLADE     17 ENABLED
  3     AP BLADE     31 ENABLED
  4     SW BLADE     39 ENABLED
  5     CP BLADE     16 FAULTY (21)
  6     CP BLADE     16 ENABLED
  7     SW BLADE     17 ENABLED
  8     AP BLADE     31 ENABLED
  9     UNKNOWN             VACANT
10     SW BLADE     36 ENABLED
Brocade support tell us to replace faulty Blade.
It was done , firmware was updated to same version than the CP#6 ( FOS 6.4.3c) but something wrong still there.
Now , we have the following
ED_48000B:admin> slotshow
  5     CP BLADE     16 FAULTY (3)
  9     UNKNOWN             VACANT
But the HA is OK:
ED_48000B:admin> hashow
Local CP (Slot 6, CP1): Active, Cold Recovered Remote CP (Slot 5, CP0): Standby, Faulted HA enabled, Heartbeat Up, HA State synchronized
1-)  What is the diffrenece betwween FAULTY ( 3 ) with FAULTY (21 ) ?
2-)  Is it HA enabled with CP redundancy or not ?
3-) Is there some place to investigate this "FAULTY " Condition for CP blades ?
Any inputs will be so welcomed.
Thanks.
Joelson
External Moderator
Re: ED48000B with CP faulty (21) before replacement and CP faulty(3) after replacement
Joelson,
try "slotpoweroff" command, remove the blade, insert again and then "slotpoweron"
if this not work, i suggest to continued with Brocade support.
TechHelp24
