Anonymous
DS300 create a simple Fabric with two switches
hi,
how can i setup a simple fabric with two ds300 switches. At the moment the two switches have an interconnect with the same admin domain id. How can i change this and how can i than setup a fabric with these two switches?
The ports on both switches with the interconnect shows this status: E-Port (Segmented)(domain overlap) ....
any suggestions?
UPDATE:
ok, have fixed the problem by changing the ID and removing the zone config.
Anonymous
Re: DS300 create a simple Fabric with two switches
you should have configured by configure command , that needs switchdisable, cgdisable and configure, set fabric.ops parameters same as the other sw, to which you are merging and then Domain ID should be different, in this case you have done it.
check switchshow, fabricshow,fabstatsshow
