Anonymous
Brocade 5100 problem
We recently bought a new Brocade 5100. I decided to check how new bootrom - U-boot works, specifically: setenv, saveenv and printenv. But after command setenv AutoLoad=no and saveenv AutoLoad variable disappeared at all. Looks like setenv and saveenv behave differently or syntax of these commands was changed (to compare with Brocade 4100 or 5000).
I am not able to use these commands in order to revert variables to their default state. Now after power cycle it stops at this point:
1) Start system.
2) Recover password.
3) Enter command shell.
And I am forced to hit “1” in order switch to start to boot.
How can I fix it?
Original (default) output from printenv:
=> printenv
AutoLoad=yes
BootromVerbose=no
InitTest=MEM()
LoadIdentifiers=Fabric Operating System;Fabric Operating System
OSLoadOptions=quiet
OSLoader=ATA()0x558bf;ATA()0x1ab0b8
OSRootPartition=hda1;hda2
SkipWatchdog=yes
baudrate=9600
bootcmd=setenv bootargs mem=${mem} ${OSLoadOptions};ataboot;bootm 0x400000
bootdelay=20
ethact=ppc_4xx_eth0
ethaddr=00:05:1E:63:12:62
hostname=sequoia
initrd_high=0x20000000
mem=520192k
preboot=echo;echo Type "run flash_nfs" to mount root filesystem over NFS;echo
netdev=eth0
consoledev=ttyS1
ramdiskaddr=400000
ramdiskfile=your.ramdisk.u-boot
stderr=serial
stdin=serial
stdout=serial
ver=U-Boot 1.1.3 (Sep 15 2008 - 19:24:24)
Environment size: 651/4080 bytes
Thank you for your advice,
Victor
External Moderator
Re: Brocade 5100 problem
vitocapri,
i think.... or better to say, i am very sure you have a big problem.
Fine
> I decided to check how new bootrom....
what is the reason you decide to change the Bootrom / Brootorder procedure ?
Your need here support from brocade to recovery the boot Procedure.
TechHelp24
Anonymous
Thanks for the answer. I did in order to see if old password recovery  procedure works the same (3900, 4100, 5000). Personally I do not think it's a  problem at all.   Thank you.
