Anonymous
7420 and distance LS
I have 2 7420 switches connected to each other running FC100. Currently, trying to set up the circuit. The switch config file sent to me shows that the port has distance configured as LS?? What is LS? I looked into the manual and it only mentions L0, L0.5, LE (under PortCfgLongDistance). Can someone point me to correct manual? Also, what is the maximum distance that the 7420 is rated for? The current application is to have an ISL of 100 km. L0,L0.5,LE will not make it more than a couple of km. Thanks.
Anonymous
Re: 7420 and distance LS
This is an update to this post. The 7420 is running OS Xpath 7.3.0. Where can I download the doc? OS Xpath 7.1.0 is the latest I can download on this website. This will probably account for 'LS' discrepancy.
