Anonymous
200e and 300 ISL possible?
Hi Guys,
Just would like to check the possiblity of a 200e (FOS 5.1.0b) connecting to a 300 (FOS 6.3.0) SAN switch.
Is it even possible? or do i need to upgrade the 200e?
What will be the recommended level to upgrade to...
Thanks in advance
Anonymous
Re: 200e and 300 ISL possible?
Its possible to ISL those with 6.1.0h on your 200e.
However 6.2.2b is recommended and as you need to upgrade anyway go for the latest release possible
Anonymous
How can I go about getting FOS 6.1 or 6.22?
Anonymous
If you have a support contract with Brocade, you can register your switch and obtain the files.
If you bought it from a vendor like EMC/HP etc go the their support or download site.
Anonymous
I am currently running ISL's between the following versions:
Fabric A
Brocade 200E - v5.3.0d
Brocade 200E - v5.1.0d
Brocade 300 - v6.4.1
Fabric B
Brocade 3250 - v5.1.0d
While this is not ideal I just needed to run this until I could transfer all my data over to my new SAN.  I have been running this way since early December and have not had any issues, but did not intend to run this configuration long term.  Just make sure to manage everything from the Brocade 300's since they have the newest firmware.
Anonymous
wow thank you guys for all the helpful reply..
One last thing.. what will be the license required for ISL between a 200E and 300?
Are they both Fabric license? I was told there is only Trunking License available. Is that true?
Anonymous
Switch with ISL's will require a fabric license, if not to port will segment.
could you post a licenseshow for the switches involved
Anonymous
Hi All,
Is downtime for attach hosts needed to create the ISL?
Lets say 200e is the orignal switch (with Hosts) and 300 is the new switch i want to attach to.
Thank you.
Anonymous
anyone?
Anonymous
No, downtime should not be neccessary
