Application Delivery (ADX)
Visitor
Brocade ADX 1000, not able to login through web after firmware upgrade.
Hi, we are using Brocade ADX 1000, I just upgrade the firmware and now not able to login through web. It didn authanticate any local user. we are able to connect through telnet/serial. I create a new user user with super user right, but still not able to login through web.
users related configurations are as:
aaa authentication web-server default local
boot sys fl sec
enable telnet password .....
no enable aaa console
username admin password .....
username ps password .....
no snmp-server enable traps locked-addr
web-management allow-no-password
External Moderator
Re: Brocade ADX 1000, not able to login through web after firmware upgrade.
Hi kashif,
-->>I just upgrade the firmware and now not able to login through web.
most probable, you set by Upgrade to boot from the Slot with NEW Firmware, where is no config.
do follow:
#copy running-config slot_number|Number
in example, if the running config is saved in slot1 you must copy to slot2
#copy running-config slot1|2
viceversa slot 2 to slot 1
#copy running-config slot2|1
save th econfig with command
#write memory
now all config are present in both Slot Primary/Secondary
if th eproblem persist, please post SNMP config here
TechHelp24
