New Contributor
Virtual fabric create issue on SAN router model 7800
Dear All,
I found out that when i create base switch on 7800 SAN router, i got the following message.
"lscfg:Unable to set the base switch attribute on this switch type as base switch is not supported."
May i know what's happenning? As i found out that EX port must be under base switch, otherwise, all EX-port will be disabled
So i have to create base switch and then move those EX port from default switch to base switch by using the following command.
lscfg --create 127 -base
But i found out that i can't create it. May i have advice on about it?
Thank you all.
Regards,
KC
