Contributor
Re: SAN switch -- not working
In web, in the Java GUI, there is not addanced mode. There is a"port administration" section, I have attached the screenshot of that file.
In the Java GUI, the switch status shows like bellow.
Power supplies monitor HEALTHY
Temperatures monitor HEALTHY
Fans monitor HEALTHY
Flash monitor HEALTHY
Marginal ports monitor HEALTHY
Faulty ports monitor DOWN
Missing SFPs monitor HEALTHY
The GBICs are IBM manufactured.
Anonymous
Are these switch modules inside the IBM BladeCenter Chassis?
If so, you have to enable the External Ports for this module. Connect to the BladeCenter Management module,
I/O Module Tasks -> Admin/Power/Restart -> I/O Module Advanced Setup -> Select the I/O module for the switch -> External Ports must be selected to enabled.
HTH
Mirage
Contributor
No, this is not IBM. this is HP B-series 2/16 switch.
External Moderator
IBM, HP, EMC, SUN, or other OEM Label, all Switch have the same Hardware, all use the same FabOS.
TechHelp24
Contributor
Ok. This switch is not in IBM bladecentre chasis.
In Web Java GUI, it shows the status of the switch is down.
If i go to switch healty report, all shows healty, except "Faulty ports monitor" = "Down".
If this is down, do i need to start some service ?
External Moderator
I have never spoker here of Bladecenter Switch.
Your have the switch show in the datasheet ( is attached ) Correct ?
This is Switch Type 26.
set from admin the command "configdefault" for details refer the CLI Guide.
you must first disable the switch with the command "switchdisable"
TechHelp24
Contributor
I have done bellow
swd77:admin> switchdisable
swd77:admin> configdefault
Committing configuration ... done.
swd77:admin> reboot
Then
swd77:admin> switchshow
switchName: swd77
switchType: 26.2
switchState: Faulty
switchMode: Native
switchRole: Faulty
switchDomain: 1 (unconfirmed)
switchId: fffc01
switchWwn: 10:00:00:05:1e:34:1a:9d
zoning: OFF
switchBeacon: OFF
Area Port Media Speed State Proto
0 0 id N2 No_Light Disabled
1 1 id N2 No_Light Disabled
2 2 id N2 No_Light Disabled
3 3 id N2 No_Light Disabled
4 4 id N2 No_Light Disabled
5 5 id N2 No_Light Disabled
6 6 id N2 No_Light Disabled
7 7 id N2 No_Light Disabled
8 8 id N2 No_Light Disabled
9 9 id N2 No_Light Disabled
10 10 id N2 No_Light Disabled
11 11 id N2 No_Light Disabled
12 12 id N2 No_Light Disabled
13 13 id N2 No_Light Disabled
14 14 id N2 No_Light Disabled
15 15 id N2 No_Light Disabled
swd77:admin> portenable 0
Operation not allowed in AD context
swd77:root> portenable 0
Anonymous
Check this.......
switchName: swd77
switchType: 26.2
switchState: Faulty
switchMode: Native
switchRole: Faulty
switchId: fffc01
zoning: OFF
switchBeacon: OFF
Buddy your switch is marked faulty. You wont be able to enable any ports. You can post the supportsave if you want me to check what error has caused this. Most likely you would have to replace the switch. If you do not want to post supportsave, then check errdump for the following error
EM-2003
Message <timestamp>, , <sequence-number>,, ERROR, <system-name>, Slot <Slot Id>
has failed the POST tests. FRU is being faulted.
Probable Cause Indicates that a field-replaceable unit (FRU) did not pass the Power On Self Tests. Please see the
/tmp/post.slot#.log file for more information. You must be logged in as root to view this log.
The slot will be 0 for non-bladed systems.
Recommended
Action
On bladed systems, try reseating the specified FRU.
On nonbladed switches, reboot or power cycle the switch.
If the problem persists:
  • Run the systemVerification command to verify that the switch does not have hardware
problems. Refer to the Fabric OS Command Reference for more information on this command.
  • On bladed systems, replace the specified FRU, otherwise replace the switch.
Severity ERROR
However if you do not want to replace it, try this - completely power-off the switch and boot it. Also try a fastboot to skip post.
Another thing is that you should not be using this switch in production.
Regards,
Biju
External Moderator
--->>> Operation not allowed in AD context
your get this error casually if all port are assigned to any create ADxxx ( except AD0 )
see with the command "ad --show" if any other AD is configured
is the switch turned on ? "switchenable" and then the command "switchcfgpersistentenable"
TechHelp24
Contributor
I am uploading supportsave. Thank you.
