New Contributor
FC5022 12-port 16Gb ESB SAN Scalable Switch cable connect
Hi, tell me what cable to connect to the console RZh-45 and mini USB?  I tried to connect through the cisco cable, through the avaya cable, without result
Broadcom Moderator
Re: FC5022 12-port 16Gb ESB SAN Scalable Switch cable connect
Hi,
Are you talking about the mini-usb:
The brocade part number is 50-1000059-01 (DB9) , it is the same cable for FC5022 and ICX 6650, ICX 7750, ICX 7450 (products). Or 50-1000122-01 (RJ45M).
The RJ45 on the console - which is not enabled by default (you need to login to the switch to enabled that interface as root, I suspect)
One external 10/100/1000Base-T RJ-45 Ethernet port with integral LEDs for link/activity and speed for debugging and field support
New Contributor
Yes, mini-usb. Thanks for information about part number.
Broadcom Moderator
Pinout is in the icx 7450 documentation
http://www.brocade.com/content/html/en/hardware-installation-guide/icx7450-installguide/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Serial%20port%20specifications%20(pinout%20-%20mini-USB).html
1
Reserved
Not used
2
UART0_RX
Debug port (data received by ICX)
3
UART0_TX
Console port (data transmitted by ICX)
4
Reserved
Not used
5
GND
Ground
