Anonymous
webtool access problems...
Hi, I got two IBM_2498_B24 (brocade 300) switches.
When I try to enter webtools, sometimes is working but after a minute or two I get a "invalid session, please close current web tools and associated windows, when you relaunch web tools, it will prompt you for login. error message.
I upgrade to the lastest firmware successfully (6.4.1a)
any idea ?
it doing it with firefox and ie8
with the lastest version of java installed.
thank you
Anonymous
Re: webtool access problems...
Try clearing cache en temp files from browser AND Java (from the config screen)
