Anonymous
Need help on LDAP authentication
BNA is managing entire fabric..
We wants to configure LDAP server authentication..
added the DNS name in network address..of BNAServer management console
1. Selected the AAA Settings tab.
2. Selected LDAP Server from the Primary Authentication list.
he selected DNS and clicked on test ..then Test Authentication window appears.
he enter login credentials..
Verifying connections to LDAP Server .. OK
Login to LDAP Server .. OK
Verify user privileges .. FAIL (The authorization failed for LDAP)----> here it fails..
Valued Contributor
Re: Need help on LDAP authentication
Hi,
What user are you testing with?
Did you also create it in the BNA?
Kind regards,
Felipon
Anonymous
Hi Felipon,
I have sent screen shot of the issue?
Did you receive it?
Valued Contributor
nope, I did not received anything. Please, post it here.
Rgds
Anonymous
Hi ,
I am not able to copy it here.
I have engaged expert.
he is helping me.. thank you for the reply.
Regards
Niklesh Reddy
Valued Contributor
Hi,
Once fixed, please, post the solution here.
Rgds,
Felipon
Anonymous
Hi Felipon,
changed the section in Authorization preference as LDAP Authorization
now it all works OK.
Regards,
Niklesh Reddy
