New Contributor
Accepted Solution
Help: How to send test MAPS snmp trap.
Does someone know how to send a test MAPS snmp trap?
External Moderator
Re: Help: How to send test MAPS snmp trap.
hu_bj,
there is no way ( or better to say is unknown to me ) to send test MAPS trap
try first follow to verify if sendmail is configured correct,
log as root and executed the command
echo "test" |sendmail -v "email_address"
now you can i.e. try to unplug a cable or whatever on the switch, and you should get a message via MAPS.
TechHelp24
Valued Contributor
I can confirm that power cable is the best tool to send SNMP traps.
New Contributor
Thank you for advise, I was searching and coud not find anything. I wanted to test it without impacting anything production. Meantime I got some traps which confirmed all seems configured correctly. Would be nice to have this option in future FOS version :), when there is an option to send normal test snmp trap. Thanks again.
