Anonymous
Brocade 300 Swicthes firmware upgrade
Hello All,
I was asked to upgrade the brocade 300 switches from its current version 6.1.0c to the latest version.  i have downloaded FOS v6.2.0c (windows Version) and unzipped the files.(Would like to upgrade these switches to 7.0.01 FOS)
I have also setup scp server to download the files to switch, when i start downloading files it say the version is not supported.
Could anyone correct if this is not the right procedure to upgrade?
Thanks in advance
Retired-Super Contributor
Re: Brocade 300 Swicthes firmware upgrade
Hi Vinod,
This forum is for Ethernet products and the 300 is a Fibre Channel SAN product.  You will get more response if you repost this to the Data Center SAN forum
http://community.brocade.com/community/forums/products_and_solutions/data_center_products
Best.
Brook.
Anonymous
Thank you Brook.. will post it there
Frequent Contributor
Hi Vinod!
Like said, you'll get more of a response if you put this particular discussion thread in the Data Center SAN Community. I have moved your thread over for you. Thank you very much for participating in our community!
Cheers,
Grace Chang
Global Community Manager
