Management Software
Anonymous
Problems Accessing Fabric Manager - HELP!
Hi All,
I have recently landed a job on a customer site to support the EMC and SAN infrastructure however as I am the only the one that knows anything about SANs or EMC I am having to get to grips with how they do things here.  (ridiculous as they are a huge company)
I have to logon to a Brocade switch.
I logon to the switch by opening up IE and entering http://<ip_address>
It then loads up Java - Version 1.6.0_16 - annd prompts for a username and password.
I enter the user name and password and it begins to load and I get this mass error message:
Exception encountered during initialization: com.brocade.web.secsan.SecureSANException: Cannot load RBACMatrix from switch:java.io.IOException: Server returned HTTP response code: 400 for URL: http://<same_ip_address_as_i_entered_above>/cal.xml
Details:
com.brocade.web.common.gui.AppContext.initContexts(AppContext.java:578),
com.brocade.web.common.gui.AppContext.init(AppContext.java:306),
com.brocade.web.common.gui.AppContext.init(AppContext.java:192),
com.brocade.web.common.gui.AppContext.init(AppContext.java:137),
com.brocade.web.common.gui.WTApplet.init(WTApplet.java:1069),
com.brocade.web.common.gui.WTApplet.init(WTApplet.java:987),
com.brocade.web.switchview.SwitchExplorerApplet.init(SwitchExplorerApplet.java:79),
com.brocade.web.switchview.SwitchExplorerApplet.main(SwitchExplorerApplet.java:318),
sun.reflect.NaitiveMethodAccessorImpl.Invoke0(Naitive Method),
sun.reflect.NaitiveMethodAccessorImpl.Invoke(Unknown Source),
sun.reflect.DelegatingMethodAccessorImpl.Invoke(Unknown Source),
java.lang.reflect.Method.invoke(Unknown Source),
com.sun.javaws.Launcher.executeApplication(Unknown Source),
com.sun.javaws.Launcher.executeMainClass(Unknown Source),
com.sun.javaws.Launcher.doLaunchApp(Unknown Source),
com.sun.javaws.Launcher.run(Unknown Source),
java.lang.Thread.run(Unknown Source),
There is an "OK" button at the bottom of the above message, I click on this and another blank Internet Explorer page appears.
Then a progress bar starts loading and it gets to 19% and then stops and does nothing else.
Any ideas what could be casuing this? it appears to be java related but I am not expert on java so I am struggling.
Col
External Moderator
Re: Problems Accessing Fabric Manager - HELP!
the error show to me as compatibility problem between IE and JAVA.
what is the IE release ?
TechHelp24
Anonymous
Thanks for the reply
IE version is - 6.0
The numbers after 6.0 are .2900.2180 - just in case it matters
External Moderator
--->>> IE version is - 6.0
This is the Problem, Java 1.6 is incompatible with IE 6, you need to use JAVA 1.4 or max. a early 1.5 Release.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
TechHelp24
Anonymous
Again thanks for the reply.
I have went to the dir:- c:\program files\java
In the java folder there was:
j2re1.4.2_08
jre1.5.0_15
jre6
I went into the dir:- \program files\java\j2re1.4.2_08\javaws
from this directory I opened javaws.exe - then selected preferences from the FILE menu.
clicked on the "java" tab and have tried ticking the "enable" box for 1.4 and unticking the boxes for 1.5 & 1.6.
I then try and logon to the switch again and get the same error.
I have done the same for the 1.5 and I get the same problem.
Am I missing something?
External Moderator
--->>> Am I missing something?
No, you have too much.
I have newer work with 3 different JAVA release, and I'm quite sure the error is caused by this mismatch of all installed release.
check please with the compatibility of FOS ( Release ? ) is loaded, is probable the error is caused by incomaptibilty between JAVA and FOS release.
TechHelp24
Anonymous
This is surely JAVA error. Pls run IE in another PC, and see whether u can access the fabric through the webtools. are you comfortable with CLI. As a UNIX expert I do all on CLI.you can do that by following command Line reference manual. or just type help at prompt and go for individual  cmnd by help cmnd. You will be able to admin the Fabric atleast
External Moderator
TechHelp24
