Management Software
Anonymous
Looking for help inside Network Advisor and 200E
1 and 3 have all yellow links a week ago the were all black. I tried disable ports enable ports and still same issue. I havent done a reboot because everything seems to be working. Does any one have any ideas what i can look into? Thanks ( They connect to IBM Chassis Switches )
Anonymous
Re: Looking for help inside Network Advisor and 200E
Yellow dotted line appears if the switches are removed from fabric . Is 1 and 3 physically connected to each other ?
