Management Software
Anonymous
[HELP]Unable to monitor 3rd party device(Aruba 650 wlc) from BNA server
I have installed a Brocade Network Advisor for trail testing, everything works fine with the brocade switches. But i'm unable to monitor 3rd party object which is an Aruba 650 Wireless Lan Controller.. i was able to discover via the sysObjectID, but it only shows up basic information such as(Status, device name, model, type etc) i need to monitor sFlow, Port utilization, CPU Utilization, temparature etc which is the most critical part..
Currently the Aruba 650 WLC has been configure with the following:
1. snmp trap-host [bna-server-ip]
2. SNMPv1 **** rw
3. port: 162
4. Type : trap
from the BNA server i keep receive spaming snmp trap info under the event section from the Aruba WLC which stated "unsupported trap. Notification SnmpOID: .1.3.6.4.1.14823.1.1.19.0.1219.
VarBinds:(.1.3.6.1.4.1.14823.2.3.1.11.1.1.60=5-)
... and so on
Is there anyone which is expert on configuring SNMP management software?
External Moderator
Re: [HELP]Unable to monitor 3rd party device(Aruba 650 wlc) from BNA server
[ Edited ]
-->>......Aruba 650 Wireless Lan Controller.
I'm not the expert with Such devices, however accordly BNA Release Notes this Controller is not Listed in Supported devices
TechHelp24
