Info & Feedback
New Member
Routing Issue
I can currently telnet into main swtich (Brocade 7250-24P) (192.168.10.1) and then telnet into remote switch (Brocade 7150-C12) (192.168.70.2) from there.  However,  I am not able to telnet to the remote switch from my laptop plugged into port 1/1/1 with an IP address of 192.168.10.114.  The configuration for each switch is as follows:
Remote Switch
telnet@ICX7150-C12 Router>enable
No password has been assigned yet...
telnet@ICX7150-C12 Router#sh runn
  running-config              Current running-config
telnet@ICX7150-C12 Router#sh running-config
Current configuration:
ver 08.0.80cT213
stack unit 1
  module 1 icx7150-c12-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-2-sfp-plus-port-20g-module
vlan 1 name DEFAULT-VLAN by port
vlan 10 name IP-Subnet_192.168.10.0/24 by port
tagged ethe 1/3/1 to 1/3/2
router-interface ve 10
vlan 70 name IP-Subnet_192.168.70.0/24 by port
untagged ethe 1/1/1 to 1/1/12 ethe 1/3/1 to 1/3/2
router-interface ve 70
aaa authentication web-server default local
aaa authentication login default local
enable telnet authentication
enable aaa console
username Admin password .....
username jbrown password .....
password-change any
clock summer-time
clock timezone us Central
web-management https
interface management 1
ip address 192.168.9.70 255.255.255.0
interface ethernet 1/1/1
port-name PLC-701
interface ethernet 1/1/2
port-name PanelView-701
interface ethernet 1/1/3
disable
interface ethernet 1/1/4
disable
interface ethernet 1/1/5
disable
interface ethernet 1/1/6
disable
interface ethernet 1/1/7
disable
interface ethernet 1/1/8
disable
interface ethernet 1/1/9
disable
interface ethernet 1/1/10
disable
interface ethernet 1/1/11
port-name Mgmt Port
interface ethernet 1/1/12
port-name Wireless AP
interface ethernet 1/2/1
disable
interface ethernet 1/2/2
disable
interface ethernet 1/3/1
port-name FS-101 Main Switch
speed-duplex 1000-full
interface ethernet 1/3/2
port-name FS-101 Backup Switch
interface ve 10
ip address 192.168.10.5 255.255.255.0
interface ve 70
ip address 192.168.70.2 255.255.255.0
end
Main Switch
telnet@ICX7250-24P Router(config-vlan-70)# show configuration
Startup-config data location is flash memory
Startup configuration:
ver 08.0.80cT213
stack unit 1
  module 1 icx7250-24p-poe-port-management-module
  module 2 icx7250-sfp-plus-8port-80g-module
tagged ethe 1/2/4 to 1/2/8
untagged ethe 1/1/1 to 1/1/24
vlan 40 name IP-Subnet_192.168.40.0/24 by port
untagged ethe 1/2/4
router-interface ve 40
vlan 50 name IP-Subnet_192.168.50.0/24 by port
untagged ethe 1/2/5
router-interface ve 50
vlan 60 name IP-Subnet_192.168.60.0/24 by port
untagged ethe 1/2/6
router-interface ve 60
untagged ethe 1/2/7
vlan 80 name IP-Subnet_192.168.80.0/24 by port
untagged ethe 1/2/8
router-interface ve 80
enable aaa console
ip default-network 192.168.10.0/24
ip route 192.168.10.0/24 ve 70
ip route 192.168.10.0/24 ethernet 1/2/7
ip route 192.168.70.0/24 ve 70
ip route 192.168.70.0/24 ethernet 1/2/7
password-change any
clock summer-time
ip address 192.168.9.10 255.255.255.0
port-name Mgmt Port
disable
disable
disable
disable
disable
disable
disable
disable
port-name Wonderware PC
disable
disable
interface ethernet 1/1/13
disable
interface ethernet 1/1/14
disable
interface ethernet 1/1/15
disable
interface ethernet 1/1/16
disable
interface ethernet 1/1/17
disable
interface ethernet 1/1/18
disable
interface ethernet 1/1/19
disable
interface ethernet 1/1/20
disable
interface ethernet 1/1/21
disable
interface ethernet 1/1/22
disable
interface ethernet 1/1/23
disable
interface ethernet 1/1/24
port-name ""
disable
interface ethernet 1/2/3
port-name ""
interface ethernet 1/2/4
port-name Pre-Treat Bldg
interface ethernet 1/2/5
port-name SBR 1-2 Bldg
interface ethernet 1/2/6
port-name SBR 3-4 Bldg
interface ethernet 1/2/7
port-name Gen_Digestor_Bldg
interface ethernet 1/2/8
port-name Dewatering_Bldg
interface ve 10
ip address 192.168.10.1 255.255.255.0
interface ve 40
ip address 192.168.40.1 255.255.255.0
interface ve 50
ip address 192.168.50.1 255.255.255.0
interface ve 60
ip address 192.168.60.1 255.255.255.0
interface ve 70
ip address 192.168.70.1 255.255.255.0
interface ve 80
ip address 192.168.80.1 255.255.255.0
end
Any ideas on what is wrong with my configurations?
External Moderator
Re: Routing Issue
@nworbj14
ICX Switch line was acquired by Ruckus, please post your question on their Ruckus Community
TechHelp24
