Fibre Channel (SAN) Technical Documents
portstatschecker
by Anonymous ‎11-18-2003 04:01 PM - edited ‎10-30-2013 01:50 PM (810 Views)
DETAILED DESCRIPTION
The script uses Perl 5 and and the Telnet.Pm. Scripts sends login parameters to switch. Switch informations must me in host file of server where script is executed from. After the login to the switch the script performs a portstatsshow command on each port. Output will be dumped to file identified by script. file will get dropped in defined path or home directory.
REQUIREMENTS
Operating System Solaris
Interface Perl 5
Fabric Operating System 2.6.0c
Other not applicable
NOTES (INCLUDING LIMITATIONS)
not applicable
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
