Fibre Channel (SAN) Technical Documents
Storage Group Create
by Anonymous ‎07-17-2006 05:00 PM - edited ‎10-30-2013 01:19 PM (389 Views)
DETAILED DESCRIPTION
Run from the command line. replace "-h 192.168.0.1" IP address with the address of your system SP. Replace the "hostname" with the title used for your new storage group. Duplicate storagegroup -create line for each new storage group to add. The "-o" will run the command lines without prompts.
REQUIREMENTS
Operating System Windows, Unix
Interface IP out of band
Fabric Operating System Works with Brocade
Other Be sure not to run this with duplicate storage group names
NOTES (INCLUDING LIMITATIONS)
This should be run at the begining of Clariion configuration. Be sure not to run this with duplicate staorge group names.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
