Fibre Channel (SAN) Technical Documents
RouteTest
by on ‎09-12-2003 01:00 AM (827 Views)
DETAILED DESCRIPTION <br/>
<br/>
With this utility, the user provides 2 wwns and it tells you the route that is currently being used between the 2 devices (you can also use domain,port references). After it gets the route - it will then check zoning to see if the 2 devices are in a zone together, tell you which one or say that the 2 devices cannot talk to each other due to zoning restrictions. <br/>
<br/>
REQUIREMENTS <br/>
<br/>
Operating System Windows NT/2K <br/>
<br/>
Interface CLI <br/>
<br/>
Fabric Operating System One of the following at a minimum:<br/>
<br/>
2.6<br/>
<br/>
3.0 <br/>
4.0 <br/>
<p/>
Other Usage: routetest <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-ipIpAddress">-ip IpAddress</a> <a class="jive-link-adddocument" href="http://community.brocade.com/home/community-document-picker.jspa?communityID=2006&subject=-uUser">-u User
