Fibre Channel (SAN) Technical Documents
PortErrorshowcollect
by Anonymous ‎09-29-2004 11:00 PM - edited ‎10-30-2013 01:47 PM (881 Views)
DETAILED DESCRIPTION
It goes through all the listed switches on switchlist file collects porterrshow information reports under errorreport.
REQUIREMENTS
Operating System Unix
Interface Perl
Fabric Operating System 4.1.x and above
Other Needs to install perl module
NOTES (INCLUDING LIMITATIONS)
It will list out the ports which are having critical errors you can find the report in a file called critical."date"
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
