Fibre Channel (SAN) Technical Documents
Fabric Explorer
by on ‎06-18-2003 04:33 PM - edited on ‎10-30-2013 01:53 PM by Anonymous (1,689 Views)
DETAILED DESCRIPTION
Windows 2000/NT GUI-based SAN Explorer that discovers switches and devices inside a fabric, and returns detailed information about the fabric and switches. Gathers critical information such as switch names, switch type, firmware versions, port information, device names, SCSI Inquiry Strings, etc.
REQUIREMENTS
Operating System NT, Windows 2000
Interface NT, GUI
Fabric Operating System One of the following at a minimum:
2.6.0d
3.0.2g
4.0.2b
Other n/a
NOTES (INCLUDING LIMITATIONS)
Install shield agent will take care of all installation issues. Application is fairly straightforward to use.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on January 23, 2008, on behalf of the author.
Contributors
