Anonymous
what is the setting in 48000 for long distance data transmission
there are two SAN 48000 switch in two site, and plan to setup an DR environment, now I have activated the extended fabric license, and need I do some other setting in 48000, the distance between two sites is less than 40 km, thank you.
Anonymous
Re: what is the setting in 48000 for long distance data transmission
Hi wgwang,
The distance setting if you're aroung 40 km will be LD. It will calculate the distance automatically and set the credits necessary for this link.
The command you would use is:
portcfglongdistance slot/port LD
Cheers
