Anonymous
script for dcx ?
Does anybody know where (if it exists) I can obtain a sample script for configure the ports on the DCX
Thank you
External Moderator
Re: script for dcx ?
There are no script general available from brocade.
TechHelp24
Anonymous
Here is some start :
SWblade=1
SWlastport=47
FOScmd=portshow
for ((SWport=0; SWport<=$SWlastport; SWport++)); do $FOScmd $SWblade/$SWport; done
And some possible options for the var's :
# SWblade = 1 ... 4 <> 9 ... 12
# SWlastport = 7 ... 15 ... 31 ... 47
# FOScmd = portshow / portcfg...
Anonymous
Try to use the range option in most of the port cfg commands.
An other way is that you can create a Execl sheet with all command you want to run and copy these commands in a putty session.
Regards,
Andreas
