New Contributor
fail to connect Web Tools from WindowsServer 2012R2
Hi,experts.
I tried to connect Web Toos from WindowsServer 2012R2 with IE11,but cannot.
JavaScript is enabled,and Java setting in Control Panel , Selected "Show console".
Is there any other setting needed?
Regards,
Broadcom Moderator
Re: fail to connect Web Tools from WindowsServer 2012R2
Hello,
Which Java release are you using?
What is the FOS release of the switches?
New Contributor
Hello,
Sorry of my reply. This problem is still not resolved.
Java 8 Update101.
FOS 7.41d
When accessing SANSW URL, IE shows below message, and close IE window automatically.
"cannot execute this web site`s add-on"
Broadcom Moderator
Hello,
FOS 7.4.1d is qualified and support Oracle Java 7 update 76 and Java 8 update 66.
New Contributor
Hello,
Need to downgrade java to 8 update 66?
In the Web tool administration guide, below message.
"Web Tools requires any browser that conforms to HTML 4.0, JavaScript 1.0, and JRE 1.7.0_80 or JRE 1.8.0_51 update or later."
Broadcom Moderator
[ Edited ]
Hello,
Attached is the release note of FOS 7.4.1d. Page 26 describes the webtools compatibility.
