Turn on suggestions
Showing results for
05-29-2016 11:49 PM
Hi
can I know the latest possible fabric OS upgrade for brocade 5000 switch, current version is 5.2.1. Please share if there is a support matrix document
Thanks & Regards,
Lakmal
05-29-2016 11:51 PM
v6.4.3h
05-29-2016 11:58 PM
Hi Antonio,
Thank you very much for your prompt reply. Can I upgade the switch stright to the v6.4.3h or is there any steps I need follow ?
Regards,
Lakmal
05-30-2016 12:09 AM
you have to follow the Targte Path, upgrade in one Step is not supported.
from 5..2 you need first to upgrade to:
FOS 5.3.2b/c -> FOS 6.0.0c -> FOS 6.1.2c -> FOS 6.2.2f -> FOS 6.3.2d -> FOS 6.4.3h
