New Contributor
Accepted Solution
fabric OS brocade switches (v6.2.2d) RADIUS/NAS
Hello good day!
I have fabric OS brocade switches (v6.2.2d) that are part of a fabric A and another Fabric B. I discovered that these switches using SSH connection can not authenticate using RADIUS unless there is in the NPS server I put the NAS mode. If I remove the NAS mode I can not access these switches.
The problem is that I have other newer switches in several fabrics in the environment that do not need the NAS in the NSP to work. Checking the RADIUS config on one of the switches, I noticed that logically the setup parameter is different from the newer switches. The issue is that I no longer have support for this switch and I am in doubt whether or not I can configure the same RADISU \ NPS settings for the newer switches on older switches, since the firmware version is high bang.
External Moderator
Re: fabric OS brocade switches (v6.2.2d) RADIUS/NAS
@ffabiosantosgcm
to be honestly, is not clear to me what exact is you question / problem / issue ?
TechHelp24
New Contributor
[ Edited ]
If there is a problem with using the switch configuration of the newer version (8.2.0b) on the older switch (v6.2.2d).
1 Fabric OS: v6.2.2d
RADIUS CONFIGURATIONS
Position : 1
Server : 192.xx.xx.xx
Port : 1812
Secret : xxxxxxxxxxxx
Timeout(s) : 3
Auth-Protocol: PEAP-MSCHAPv2
2 Fabric OS: v8.2.0b
Position : 1
Port : 1812
Secret : xxxxxxx
Timeout(s) : 10
Auth-Protocol : PAP
Encryption level : NONE
Super Contributor
Hello,
there is only difference in auth protocols as some of them become obsolete .
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
New Contributor
Does Brocade support configuration of - Radius Attribute 32 - NAS-identifier? Switch Fabric OS: v6.2.2d??
New Contributor
I was able to solve the problem. It was setting the NAS Identifier in rule in the NPS. I made a move and solved it.
Warning for switches in version 6 that use NAS Identifier. The newer switches do not accept this condition.
