Anonymous
b6505 base model with one PS/fan shows alarm in webtool
B6505 base model with one ps/fan shows alarm in web tool , goes off if i insert the second one . Is there brocade document confirming this ?  FOS is 7.4.0a , so here we have default MAPS policy enabled and the rule to check this ps/fan checking and setting the switch status to marginal . IS there a way to edit or modify this default maps policy / rule .
Any help will be appreciated .
Raj
Valued Contributor
Re: b6505 base model with one PS/fan shows alarm in webtool
from what i know, you cannot edit default policies. what you should do is to create a copy of the default policy, modify this copy and apply it to the switch.
Anonymous
Yes, you have to clone the default policy and edit the cloned policy. Afterward, you can activate the cloned policy. But you need a policy to do that.
