Anonymous
Using JNI FCE-6460 HBAs (on Solaris systems) with Silkworm 2800s
Hello everyone,
Anonymous
Re: Using JNI FCE-6460 HBAs (on Solaris systems) with Silkworm 2800s
thumper - I think you have a 3800 switch. But in any case what do your zones look like? Is there any other server using the switch? Looks like you have it narrowed down to the switch as the point to point works fine. When you log in to the switch do you see the Array and the hba when you do a switchshow? if that looks OK then I would verify the zoning configuration. IF there are no other servers on the switch you can blast the complete zoning config. I would do a backup first. If that works redo the zoning if not I would check your licenses. Good luck
