New Contributor
The difference between ifHCOut/InOctets MIB object for gex and VEx
Hello we are measuring FCIP transfer rate by polling the subject MIB objects every 5 minutes and calculate the delta (devided by 300secs). .An FCIP tunnel VE16 involves only one circuit on ge0 in our configuration so I thought that  ifHCOut/InOctets for VE16 and ge0 would be the same but these objects for ge0 always show higher  transfer rate than those forVE16 in our installation  and here are my questions:
Q1.  Why (in our installation) ge0 has higher transfer rate than VE16?
I am coming to assume that the transfer bytes at VE level dooes not take accouunt TCP/IP headers while the transfer bytes for ge0 does take account these headers.  Can somebody endorse me or explain?
Q2.  Sometimes I see the calculated transfer late (for VE)  is over 1GB/sec that cannot happen as we use 10GbE (i.e., 10Gbps hence 1GB/sec for 8B/10B)  we would like to know the reason for that.
An examplle of actual calculated value is about 1.07GB/sec which is too big to quote 'it is within an error range at the given interval'....
Many thanks in advance!!
External Moderator
Re: The difference between ifHCOut/InOctets MIB object for gex and VEx
@hgpark
excepted you don't have Gen6 SX6 Extension Blade, where all features are enable in FOS 8.x by default;
can you please specified the type of hardware and license ?
is a FX8-24 Blade or 7840 ?
TechHelp24
New Contributor
I appreciate you for the prompt response on this topic.
My apologies for not including hardware/license information.
Our installation uses SAN06B-Rs(or 7800s) which is:
  •  Running at 7.4.1d level of FOS
  • Activated licenses include:
    • Enhanced Group Management
    • Fabric Watch license
    • 7800 Upgrade License
We do *not* have or use advanced extension license..
Hope the above helps understand our installation.
Thank you!!
New Contributor
[ Edited ]
My apologies but I took the interface wrong..  As we are using SAN06B-R(7800), the network interface is GbE and NOT 10GbE so the Q2 above should read::
Q2.  Sometimes I see the calculated transfer late (for VE)  is over 100MB/sec that cannot happen as we use GbE (i.e., 1Gbps hence 100MB/sec for 8B/10B)  we would like to know the reason for that.
An examplle of actual calculated value is about 107MB/sec which is too big to quote 'it is within an error range at the given interval'....
Again, sorry for the confusion that might have caused.
Thank you!!!
