Occasional Visitor
Accepted Solution
Storage Bonding to FC Switch need URGENT help
Hi
I have recently bonded 2 HBA Cards on my Fujitsu storage device
Storage 1
Bond 1 : 10.10.203.13     GW 10.10.203.1
Bond 2 : 20.20.203.13     GW 20.20.203.1
Media Server IP : 10.10.203.18
This connection when directly connected to the Media Server (IBM ) works perfectly but when
we connect it to the FC i am no longer able to access the GUI from the second bond but works from the first bond
I can ping and access the CLİ but cannot access the GUI or get Symantec to see the device from the second bond .
I am assuming there is a conflict somewhere but cannot figure out where
We also have two more storages
Storage 2 CS800 S6
Bond1 : 20.20.203.14 GW 20.20.203.1
This also has the same issue when going through a switch i am ubanle to access the GUI but can ping and acess the CLI
Storage 3
CS800 S5
No bonding done but to give everyone a full picture it is directly connected to the media server
Eth 21 : IP 20.20.203.8 GW 20.20.203.1
This works as well as it is directly connected not through the switch
For some reason when the switch is connected we lose connection on the 20.20 ip addresses
   Media Server 1 :  10.10.203.18 GW 10.10.203.1
   Media Server 2   : 20.20.203.9   GW 10.10.203.1
Can anyone give me some input whether it might be a routing issue or something else i am stuck on this one
External Moderator
Re: Storage Bonding to FC Switch need URGENT help
@Turkish83
sorry my ignorance, what is a "Bond" ?
additional you talk here about FC Switch, connected via IP ????
can you please clarified ? Standard FC Switch don't really support IP Protocols.
post please a Draw, and exact Switch Type/Model and FOS / Firmware release.
TechHelp24
