Anonymous
Accepted Solution
Power Off and Power Up procedure for Brocade SAN Director
Hi All,
We are going to relocate our SAN directors in to another RACK in order we need to know the standard Power off and Power Up procedures for Directors and also If any instructions to be followed during Relocation would be more helpful.
Thanks,
Nayab
External Moderator
Re: Power Off and Power Up procedure for Brocade SAN Director
[ Edited ]
use the command "sysshutdown" to shutdown the FOS.
by 48000 and old Directors, wait for appr. 60 Seconds, and the power off the Switch.
if you have DCX, ( I've never test ) this shold Power Off by shutdown but I'm not sure. If no, use same procedure as 48K
after relocation you need simple to do Power-On
TechHelp24
Valued Contributor
I confirm that DCX and 8510 chassis do not turn off by themselves on sysshutdown. So you should wait a while and then turn off the power supplies.
