Occasional Contributor
Accepted Solution
Portbuffershow strange output
Hello
I havve the following  output of the portbuffershow command on Brocade 6510 switch with  FOS 7.2.1d
O-Brocade-3:FID128:admin> portbuffershow
User     Port     Lx     Max/Resv  Avg Buffer Usage & FrameSize    Buffer
Needed     Link     Remaining
Port     Type    Mode    Buffers        Tx         Rx              Usage
Buffers   Distance  Buffers
  0       F       -         8       - ( 648)      - (  44)           8  -
  1       F       -         8       - ( 620)      - (  32)           8  -
  2       F       -         8       - (  - )      - (  - )           8  -
  3       F       -         8       - (  - )      - (  - )           8  -
  4       F       -         8       - ( 572)      - (  52)           8  -
  5       F       -         8       - ( 720)      - (  52)           8  -
  6       F       -         8       - (  36)      - ( 820)           8  -
  7       F       -         8       - (  36)       1(1220)           8  -
  8       F       -         8       - (  80)      - ( 584)           8  -
  9       F       -         8       - ( 852)      - ( 308)           8  -
 10       F       -         8       - (  32)      - ( 584)           8  -
 11       F       -         8       - ( 148)       3(3704)           8  -
 12       F       -         8       - (  - )      - (  - )           8  -
 23       E      LS       422       93( 456)     253(1232)         214
214        13km
 24       F       -         8       - (  68)       1(1720)           8  -
 25       F       -         8       - (  - )      - (  - )           8  -
 26       F       -         8       - (  - )      - (  - )           8  -
 27       F       -         8       - (  - )      - (  - )           8  -
 28               -         8       - (  - )      - (  - )           0  -
 29               -         8       - (  - )      - (  - )           0  -
 30               -         8       - (  - )      - (  - )           0  -
 31               -         8       - (  - )      - (  - )           0  -
 32               -         8       - (  - )      - (  - )           0  -
 33               -         8       - (  - )      - (  - )           0  -
 34               -         8       - (  - )      - (  - )           0  -
 35               -         8       - (  - )      - (  - )           0  -
 36               -         8       - (  - )      - (  - )           0  -
 37               -         8       - (  - )      - (  - )           0  -
 38               -         8       - (  - )      - (  - )           0  -
 39               -         8       - (  - )      - (  - )           0  -
 40               -         8       - (  - )      - (  - )           0  -
 41               -         8       - (  - )      - (  - )           0  -
 44       E       -         8        9(9564)      - ( 240)          26
26         2km
 45       E       -         8        5(5772)      - (  - )          26
26         2km
 46       E       -         8        5(5736)       9(10048)          34
34         2km
 47       E       -         8       - ( 852)       2(2600)          34
34         2km      7106
I  think that output  concerning Avg Frame size  is a bit strange on  ports 11,44,45,46,47. It is well known  that frame size should be less than 2148.  Can  anyone explain those IMHO strange values  of the Avg Frame size.
Thank  you
Broadcom Moderator
Re: Portbuffershow strange output
Hello,
If you are running FOS version below 7.4, this is coming from a defect referenced into FOS 7.4x release notes. Defect # 533329.
Hello Thierry
I am Running FOS ver 7.2.1d
Broadcom Moderator
So fix for that is included into 7.4x releases.
Thierry. Thank  you  for your help
