Occasional Contributor
Re: Poor performance and latency issues
Here's an output for the Rx Tx power.
SFPRxPowerdBm SFPRxPoweruW SFPTxPowerdBm SFPTxPoweruW
-3.2 483.8 -3.3 467.9
-4.4 362.5 -2.7 537.8
-3.4 454.8 -3 506.7
-3.4 454.8 -3 506.7
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-3.8 414 -2.4 582.1
-2.4 578.3 -2.4 574.1
-2.7 541.7 -2.6 543.4
-1.9 651.2 -2.5 559.1
-3.9 403.5 -2.4 577.6
-3.5 451.8 -2.4 574.8
-2.4 575.6 -3.4 453.1
-2.6 550.3 -2.6 547.2
-3.7 429.8 -3.5 447.1
-3.2 478.1 -2.5 563.1
-1.5 709 0.2 1057.6
-2.2 606.4 -3.2 483
-2.1 610.4 -3.3 471.7
-2.1 622.9 -2.4 578.9
-2.5 563.3 -2.4 573.4
-2.6 550.8 -2.6 555
-3.1 486.8 -2.5 562.8
-11.5 70.8 -2.5 567.9
-13.4 45.5 -2.4 574.2
-11.1 78.3 -2.3 592.7
-11.3 73.7 -3 503.5
-11.3 73.7 -3 503.5
-10.2 95.3 -2.6 550
-10.2 95.3 -2.6 550
-9.3 118.2 -2.6 551.1
-3 497.7 -2.3 591.7
-3 497.7 -2.3 591.7
-2.8 522.8 -2.4 577.2
-3.6 432.1 -2.3 587.7
-3 497.9 -2.3 594.5
-3.1 494 -2.7 542.8
-3.6 435.8 -2.3 585.7
-2.9 514.6 -2.2 607.7
-2 631.3 -2.4 573.3
-2 631.3 -2.4 573.3
-2.2 607.6 -2.2 603.7
-2 625 -2.3 592.3
-2 625 -2.3 592.3
-2.6 543.6 -2.2 607.1
-2.6 544.8 -2.3 588.4
-2.8 528.2 -2.2 600.9
-2.6 553.1 -2.2 600.6
-3.4 458.4 -2.2 605.8
Regular Contributor
This grouping is rather low. Is this RX or TX? (I would assume RX...)
-11.3 73.7 -3 503.5
-11.3 73.7 -3 503.5
-10.2 95.3 -2.6 550
-10.2 95.3 -2.6 550
I would recommend reviewing all the cabling.
Regular Contributor
If you want to see the ports associated with this, run:
sfpshow -all | grep -e Port -e Power
The grep portion is case sensitive.
Regular Contributor
Yes, All are set to AutoNegotiate, and I've found that one of the ISLs detects the speed as 8G, despite the fact that the SFP is 16G. I will set the speed to manual.
I would recommend not setting the speed to manual as it might cause other issues. Instead, it does look as though we have something specific to look at. IE: That port/cable set.
I will review the cables, and I won't set the speed to manual as recommended.
Thanks,
Regular Contributor
With a port to focus on, there are quite a few commands that could shed some light (pun) on the issue.
errdump (with a text capture)
porterrshow
portlogshow
portlogshowport
portshow
portstatsshow
Other commands that might be useful:
trunkshow
fabricshow
islshow
These are a good starting place.
