Anonymous
Planning for Brocade 2x5300 firmware upgrade from 6.2.1b and going to 6.3.2 and then to current 6.4.0b.
I would like to know, can it be done undistruptive upgrade ?
where can I get the procedure/manual for non distruptive upgrade ?
Appreciate your reply.
Anonymous
Re: Planning for Brocade 2x5300 firmware upgrade from 6.2.1b and going to 6.3.2 and then to current 6.4.0b.
The code upgrade can be non disruptive for
1. Director class switches, since the failover time is approx 2 ms as opposed to 40-60 ms for pizza box switches. I normally do a controlled upgrade to ensure that all events happen as planned. The default method is to just run the firmwaredownload command which works for many a customer as well.
2. For resilient and redundant SAN's with properly configured multipath software.
Regards,
Biju Krishnan
TechHelp24
Email: bkrishnan@techhelp24.com
Site: www.techhelp24.com
Anonymous
The attached doc may help you. Also before upgrading the FOS, pls check the compatibility of HBA firmware and Microcode of storage sas well as multipathing SW . In extreme cases , some AIX machines behaves differently after doing FOS upgrade. First upgarde one Fabric and wait for 1 week and then upgarde the other fabric.  You can try it in ur UAT set up, if you have then in production.
