Turn on suggestions
Showing results for
02-16-2010 05:42 AM
I have a second hand IBM Totalstorage SAN12m1/rebadged sphereon 4300). The person I bought it from does not have the IP/Admin login info. So I connected to the system with a DB9 cable and booted it.
I don't get a > prompt to login - below is the output at the maintenance port. Am I simply missing something or if not is there something I can do to try and get a prompt - or do I have a conversation starter?
Port settings are set as desribed in the IBM/brocade service manual for the model.
Thanks in advance
Target Name: vxTarget
User: target
Attached TCP/IP interface to emac unit 0
Attaching network interface lo0... done.
NFS client support not included.
VxWorksCopyright 1984-1998 Wind River Systems, Inc.
CPU: IBM PowerPC 405GP Rev. E
VxWorks: 5.4.2
BSP version: 1.2/6
Creation date: Oct 9 2003
WDB: Ready.
SSP0: Subsystem initialization starting
total 0
badsum 0
tooshort 0
toosmall 0
badhlen 0
badlen 0
infragments 0
fragdropped 0
fragtimeout 0
forward 0
cantforward 0
redirectsent 0
unknownprotocol 0
nobuffers 0
reassembled 0
outfragments 0
noroute 0
SSP0: Subsystem instantiation completeCurrent trace area is set to 0 for subsystem 1 (AS)
SNMP: subsys initFAF_MODEL_SPECIFIC_INFO::unknown IBM Model Number(7) for 12-port machine
SSP0
SNMP: agent_task begins...LOGIN_SERVER: subsytem reg with nid_db change tsk= 2245b18 index= 0
LOGIN_SERVER: subsytem reg with rtin_db change tsk= 2245b18 index= 0
SSP0: FcpPrvt:FcpSrvrTskRng.
The Embedded Web Server has been enabled.SSP0: MS_ROUTER::_main_task() checking integrity of repl. db's now.
The Command Line Interface has been enabled.
Route Manager Routing Task running
SSP0: Path Selection Manager entering serviceRoute Manager Zoning Task running
Route Manager Rerouting Task running
Route Manager Flow Task running
Route Manager Link Task running
SSP0: Login Server entering serviceSSP0: Name Server entering service
Fabric Paths Available
Fabric Processes Completed
SNMP: trap_task begins...
02-16-2010 10:20 AM
Power OFF the switch.
Connect Serial Cable
Open a Telnet Connection and Power ON
Press Enter or ESC immediately when Boot procedure begin.
Your are in the prompt Log-In.
02-16-2010 11:25 AM
Will give it a try tonight and get back to you.
Thanks.
02-16-2010 08:09 PM
Well that did not help.
I must not be hitting the Esc key or enter key at the right time as it just scrolls right on by until the snmp trap task - and than stops outputting more information or responding to key strokes.
Pressing and hold either key and than booting the switch only ends up with me crashing putty.
On the bright side I was able to discover the IP address by doing a TCP dump - bad news is still no clue about the password and trying to browse to port 80 get's me a http 400 error.
Any other thoughts?
