Anonymous
M4500 and 4700 need quick Help
Hi Every one ,
Are Spherion M4500 & Spherion M4700 need switch reboot while performing the FW Upgrade ?
Quick Ans are appreciated ..
Thanks
Babu Antony
Super Contributor
Re: M4500 and 4700 need quick Help
YES
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
Anonymous
Will the reboot affect the host since it has the EFC Management software -- it provides advanced functions such as non-disruptive code activation
Is it not ?
Thanks
Babu Antony
Super Contributor
Antony
you aksing for,
--->>>...need switch reboot while performing the FW Upgrade ?
and the answer is Yes, Switch must reboot after FW Upgrade.
Since EOS 9.6, Upgrade is non-disruptive for attached devices
Thank you.
